LOLLIPOP PHONES DON'T WORK ON MIKROTIK x86 v6.30 . normis
LOLLIPOP PHONES DON’T WORK ON MIKROTIK x86 v6.30
i asked : hi guys i have problem with lollipop phone they connect to the server but without internet and they don’t open sign in page for hotspot pleaz help my clintes start to be mad
forgive my english it’s not that good
you’r answer :
many questions need to be answered:
  1. you have wireless probably. in this x86 or a separate AP?
  2. only lollipop devices? iphone, android with older OS, all work fine?
  3. if they open some webpage in the phone, what happens?
  4. in the router, do you see any LOG about this connection?
    my answer :
    1.separates APs
    2.yes only lollipop phones
    3.This webpage is not available
    4.no there is no LOG about thes
    thankes
Install 6.30.2 bugfix release.
Hello I have the same problem in my network with Mikrotik 6.30.2 mobile lollipop just have this problem when other network as well as trying to work all mobile phones
I would like to tell you something I know what the problem is but I do not know the solution
how can i send to you a pic??
I have the same problem ..
BoooDa How can I contact with you to resolve the problem?
was it working with older RouterOS version?
Which version is working for you?
We tried all kinds of Lollipop phones, they all work fine. Maybe the issue is not with the Phone OS but something else.
yes i think we have a ipv6 issu but we are not that good in mikrotek
but what we have in the end as we think some kind of routers that they have an ipv6 dhcp server and making the issu
note : my phone is on lollipop 5.0.2v if maked it bypassed and start hotspot app it’s work fine . and the issu not in all times
and my router verion 6.30.2 (x86)
Hello Everyone, First post no Mikrotik. I’m on my 4th day with Mikrotik.
I had the same problem with Android devices using a AP device connected to a router (ClearOS.) I found that the AP was not a true AP bridge. I found a cheap $30 (new) D-Link DAP-1360 AP that works great (IPv4.) But what I did find out about some AP devices is that they are wireless routers without the switch ports and would not pass (bridge) the packets and the ClearOS router (Firewall) would drop them. Android doesn’t like TKIP or WPA. I use AES and WPA2. I’ll work on the IPv6 this weekend and post if I have any problems.
Just my 2 cents to help you.
David
Here is a link about the time on Android was the problem.
https://code.google.com/p/android/issues/detail?id=35337
then how i should resolve the problem ?
i think the whole problem is lollipop phone support ipv6 and on my network ther is some routers that they divide dhcb ipv6 and all my network is access points bridge
if i can contact with some one whos speak arabic pleas
Is there anything new about this problem
Is this still a wide-spread issue as I seem to be having the same problem with v6.33? I wanted to check whether the latest updates should have fixed the fault, as if so, the problem I’m having may be due to something else. I’ve recently bought a second-hand Nexus 5 running Lollipop from a used for sale site online. I’m concerned that the phone might be the problem but then I have tried it on different setups and I don’t have any issues. Like Khaleday12, I could probably do with talking through my issue with someone on the phone if possible.
If someone could confirm whether this is still a known fault in the meantime, I’d be very grateful?
