Hi!
Is it really necessary to have long address lists (example: firewall filter check blacklisted IPs) in router? Perhaps there is some way to read this information (IPs) directly from file on router or from local server (without adding 5000+ lines in address list section)? When are so much unimportant lines, easy can miss some relevant data + loading to see take some time and resources…
So, is this possible? ![]()
You can script it.
Sent from my SCH-I545 using Tapatalk
Sorry, but I dont understand you…
I already have address list with 5000+ entry`s added by script on router, but I want that firewall filter check one file.txt rather than long address list - I cant find info easy anymore…
The best you can do is to have a script load the file into the address list.
Sent from my GT-P3110 using Tapatalk 4
already done ![]()
SO, there is no other way to read data for filter than just from address list?
Maybe Mikrotik specs can build something up in new versions?
Where can I post a sugesstion? ![]()
As I see it, I should be much faster to have the list in memory than in a file. File would need to be loaded to memory for the router to process it and that would be as if it was in memory in the first place.
