I have a router (RouterBoard) on a tower that has an ethernet run of over 350’. I can get communication to the router when I have the router in 10Mb Full Duplex without any problem. However, I need to be able to run the router in 100MBit Full Duplex in order to take advantage of the radios throughput. What do I have to do in order to take advantage of the Long Cable mode in the routerboard? Do I need a routerboard on both ends? Do any switches support the long cable mode of the RouterBoard ethernet adapters?
How would you enable long-cable mode i have tried but my software does not seem to have it.
I am using v2.8.11, and a 230 routerboard with the DP83816A chipset
Any help would be greatly appreciated
[admin@RB230] interface ethernet> pr
NAME MTU MAC-ADDRESS ARP
0 R ether1 1500 00:0C:42:03:0B:5C enabled
[admin@RB230] interface ethernet> set ether1
arp disable-running-check full-duplex mtu speed
auto-negotiation disabled long-cable name
[admin@RB230 interface ethernet> set ether1 long-cable=
no yes
[admin@RB230] interface ethernet> set ether1 long-cable=yes
