I hope someone can help me with the issue I’m having… I’ve spent so much time trying to debug this and I still can’t understand what the problem is.
My network scheme is as follows:
[Modem] <=> [Switch] ... 50m cable ... [Station].
- [Modem] = MikroTik Chateau LTE 12.
- [Switch] = MikroTik Switch RB260GS.
- [Station] = any network device on the other end of the long cable. I tried a few laptops, routers, adapters etc.
The cable is long and old and goes to another house and the station connects to the switch @100mbps even though both of them are capable of 1gbps. But that’s not the problem.
The problem is:
- Speedtest.net on the station shows 12-13mbps only.
- Mikrotik => Tools => Bandwidth test [Modem] <=> [station] shows 95mbps! (???)
The problem must the the long cable, right? Most probably yes, but just to be sure, I decided to drop out the switch and connect the cable directly to the LTE modem:
[Modem] <=> ... 50m cable ... [Station]
Works fine! The speed is ~100mbps.
Okkkk, so the switch works fine without the long cable, and the long cable works fine without the switch, but they don’t work fine together. Bad luck, let’s try another switch… I brought a few other switches I found in my junk box. Using those old switches, I get 25-30mbps, but still far from the speed of the direct connection.
Next I decided to use something else instead of the long cable. I bought a 100mbps linovision coax adapter and installed that in place of the old long cable. The adapter is rated 100mbps up to 1km distance, more than enough for my needs. My new scheme is as follows:
[Modem] <=> [Switch] <=> [Coax] <=> [Station]
Which gives me (surprise!) a speed test of 13mbps on the station…
And it also gives me a 95mbps if I drop out the switch!
Exactly the same results as I had with the 50m cable.
Honestly, I don’t understand why this is happening. Why is the switch connection to the station so much slower than direct connection to LTE modem?
Any help or ideas would be very much appreciated.
