Hi, I have really weird problem with my home network.
I have RB2011 configured as router and 2x hAP ac2 configured just as switches.
And it would seem that everything is ok because when I connect my devices (notebook, PC etc) to one of the switches, I get IP address and access to internet BUT the problem is that it takes a long time. I see Ethernet Identifying for approximatly 30 seconds.
However when I connect my PC directly to RB2011 it works perfectly and I get IP Address immediately.
Do you have any ideas what is the cause?
EDIT: (added configurations)
Switch export output:
# 2023-11-17 18:22:10 by RouterOS 7.11.2
# software id = GILK-XLQ8
# model = RBD52G-5HacD2HnD
# serial number = A97709F1AB4C
add name=br_lan protocol-mode=stp
/interface wireless
# managed by CAPsMAN
# channel: 2412/20-Ce/gn(17dBm), SSID: Mikrotikus-vacuum, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
# channel: 5640/20-eCee/ac/DP(24dBm), SSID: Mikrotikus, CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
add bridge=br_lan interface=ether1
add bridge=br_lan interface=ether2
add bridge=br_lan interface=ether3
add bridge=br_lan interface=ether4
add bridge=br_lan interface=ether5
/interface ovpn-server server
set auth=sha1,md5
/interface wireless cap
set certificate=request discovery-interfaces=ether1 enabled=yes interfaces=\
wlan1,wlan2
/ip dhcp-client
add interface=br_lan
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=cap2
/system note
set show-at-login=no
Router export output:
# 2023-11-17 18:30:09 by RouterOS 7.11.2
# software id = TGGM-B9HH
# model = RB2011UiAS-2HnD
# serial number = 444A02CD946F
/caps-man channel
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5180,5200,5220,5240,5745 name=channel2
add band=2ghz-g/n control-channel-width=20mhz frequency=2412,2437,2462 name=channel2.4
add name=br_lan protocol-mode=none
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=SALON1
set [ find default-name=ether3 ] comment=SALON2
set [ find default-name=ether4 ] comment=GABINET1
set [ find default-name=ether5 ] comment="NIE DZIALA Z JAKIEGOS POWODU"
set [ find default-name=ether6 ] comment=GABINET2
set [ find default-name=sfp1 ] disabled=yes
/caps-man datapath
add bridge=br_lan client-to-client-forwarding=yes local-forwarding=no name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security1
/caps-man configuration
add country=poland datapath=datapath1 mode=ap name=cfg1 rx-chains=0,1,2,3 security=security1 ssid=Mikrotikus tx-chains=0,1,2,3
add channel=channel2.4 country=poland datapath=datapath1 mode=ap name=cfg2 rx-chains=0,1,2,3 security=security1 ssid=Mikrotikus-vacuum tx-chains=0,1,2,3
/interface lte apn
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=dom supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n basic-rates-b="" channel-width=20/40mhz-eC country=poland frequency=2472 installation=indoor mode=ap-bridge name=WIFI rate-set=configured security-profile=dom ssid=Mikrotikus station-roaming=enabled \
supported-rates-b="" tx-power-mode=all-rates-fixed wireless-protocol=802.11 wps-mode=disabled
add name=pool_lan ranges=192.168.50.100-192.168.50.254
add name=pool_wlan ranges=192.168.60.2-192.168.60.254
add name=pool_vpn ranges=10.0.0.100-10.0.0.255
add address-pool=pool_lan interface=br_lan lease-time=10m name=dhcp_lan
/port
set 0 name=serial0
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=10.0.0.1 name=ipsec_vpn remote-address=pool_vpn use-encryption=yes
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=cfg2 name-format=identity
add action=create-dynamic-enabled master-configuration=cfg1 name-format=identity
add bridge=br_lan ingress-filtering=no interface=ether2
add bridge=br_lan ingress-filtering=no interface=ether3
add bridge=br_lan ingress-filtering=no interface=ether4
add bridge=br_lan ingress-filtering=no interface=ether5
add bridge=br_lan ingress-filtering=no interface=ether6
add bridge=br_lan ingress-filtering=no interface=ether9
add bridge=br_lan ingress-filtering=no interface=ether10
add bridge=br_lan ingress-filtering=no interface=ether7
add bridge=br_lan ingress-filtering=no interface=ether8
/interface bridge settings
set use-ip-firewall-for-vlan=yes
set loose-tcp-tracking=no
set discover-interface-list=dynamic
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set authentication=mschap2 default-profile=ipsec_vpn enabled=yes use-ipsec=yes
set auth=sha1,md5
/interface wireless access-list
add comment="Mi Mix 2s" mac-address=F4:60:E2:E4:B0:0C
add comment=Mi9 mac-address=A8:9C:ED:E4:71:00
add comment="Laptop Asus" mac-address=AC:7B:A1:B4:C2:47
add comment="Laptop Thinkpad" mac-address=8C:C6:81:F4:8B:3E
add authentication=no forwarding=no
add address=192.168.50.1/24 interface=br_lan network=192.168.50.0
/ip dhcp-client
add interface=ether1
/ip dhcp-server lease
add address=192.168.50.10 client-id=1:70:85:c2:89:99:dd comment=PC mac-address=70:85:C2:89:99:DD server=dhcp_lan
add address=192.168.50.241 client-id=1:0:4:30:b1:b4:47 comment="Dekoder Netia" mac-address=00:04:30:B1:B4:47 server=dhcp_lan
add address=192.168.50.240 client-id=1:0:d9:d1:d8:44:81 comment=PS4 mac-address=00:D9:D1:D8:44:81 server=dhcp_lan
add address=192.168.50.196 client-id=1:2c:ff:65:fc:1b:7a comment="DRUKARKA OKI" mac-address=2C:FF:65:FC:1B:7A server=dhcp_lan
add address=192.168.50.2 client-id=1:b8:69:f4:8a:61:78 comment="CAP SALON" mac-address=B8:69:F4:8A:61:78 server=dhcp_lan
add address=192.168.50.3 client-id=1:b8:69:f4:8a:60:22 comment="CAP GABINET" mac-address=B8:69:F4:8A:60:22 server=dhcp_lan
add address=192.168.50.0/24 dns-server=192.168.50.1 gateway=192.168.50.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip firewall address-list
add address=192.168.50.0/24 list=LAN
add address=192.168.60.0/24 list=WLAN
add action=accept chain=forward comment="Accept established and related" connection-state=established,related
add action=accept chain=forward comment="Accept LAN" in-interface=br_lan out-interface=ether1 src-address-list=LAN
add action=accept chain=forward comment="Accept VPN" disabled=yes out-interface=ether1 src-address=10.0.0.0/24
add action=accept chain=forward comment="Accept port forwarding" connection-nat-state=dstnat disabled=yes
add action=drop chain=forward comment="Drop rest"
add action=accept chain=output comment="Accept output"
add action=accept chain=input comment="VPN IPSec" disabled=yes in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input comment="VPN IPSec" disabled=yes dst-port=500,1701,4500 protocol=udp
add action=accept chain=input comment="Acceot CAP" dst-port=5246,5247 protocol=udp
add action=accept chain=input comment="Accept established and related" connection-state=established,related
add action=accept chain=input comment="Accept icmp" protocol=icmp
add action=accept chain=input comment="Accept DNS from LAN" connection-state=new dst-address=192.168.50.1 dst-port=53 in-interface=br_lan protocol=udp src-address=192.168.50.0/24
add action=accept chain=input comment="Accept winbox from LAN" connection-state=new dst-address=192.168.50.1 dst-port=8291 in-interface=br_lan protocol=tcp src-address=192.168.50.0/24
add action=drop chain=input comment="Drop rest"
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.50.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.60.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=10.0.0.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote
/lcd
set default-screen=interfaces enabled=no touch-screen=disabled
/ppp secret
add name=michal profile=ipsec_vpn service=l2tp
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system note
/system routerboard settings
# Firmware upgraded successfully, please reboot for changes to take effect!
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
