Just got started with the Mikrotik system and cant seem to figure out how to limit output from a command to screen at a time similar til “| more” in a normal unix CLI. The “Manual:Console” in the wiki dont seem to have the answer. Can anybody help me out?
By default the CLI paginates - have you got some weird termtype set?
Hmm - my TERM is not that strange. Default terminal on OSX:
TERM_PROGRAM=Apple_Terminal
TERM=ansi
SHELL=/bin/bash
Some commands won’t page (/log print & /export for example). Does this apply to all commands? What version of ROS are you running?
It was /log print that was the only command where I had the issue, so you comment suggests that this is by design! Thanks.
