Hi to all.
I,m new here and need some help.
I prefer MikrTik devices !
Need the best MikroTik indoor 2.4 GHz AP with long range coverage !
Need coverage : 360* - distance : 25 meters !
Thnx.
If you do ceiling mount, you should get 25m radius coverage with wAP in an open area. The distance depends on the obstructions available in the area such as walls or other objects.
https://routerboard.com/RBwAP2nD
or https://routerboard.com/RBwAPG-5HacT2HnD
When I first read your post, I assumed 25k meters - whoa - that would be a huge major design … I know, I have several I have been trying to decominish over the last year now that I have the 5 GHz nv2 system and fiber system installed.
Anyways, in answer to your question, put it high and in the center of everything. If it has an external antenna, you might try pointing it straight up or straight down.
North Idaho Tom Jones
Something like a Groove would also do, it has a nice 6dBi Omni antenna included in the box:
https://routerboard.com/RBGrooveA-52HPn
Hi Normis, is there anywhere to find information about the beam pattern(radiation pattern) of these Access Points (antenna)? Are they basically omni in terms of radiation characteristics?
Yes, Omni, spherical pattern
