Long range network nanobeams
Is it possible to connect multiple networks connection back to mikrotik router
Using nanobeam m5
i want to connect two other networks back to mine
Wonderif if its possible to use their internet bandwidth as well
Like joining three connections to one
And then sharing so any one site can use all the badnwidth of the three sites.
Then my next question would be
If i can send two internet connections on one
Nanobeam network.
For reliability and redundancy for instance
If site 3 has inernet coming from site 1 and site 2
And if site 1 goes down then site 3 will still be online via site 2
#chupaka would like to hear your input..
You would be better off sticking to Mikrotik clients or if you are going to use UBNT, go UBNT dedicated point to point.
It will work, but not nearly as well. I’ve got a lot of intermixed equipment on my network. It works, but there are strange issues that get worse with scale. If you have less than 10 clients, it will probably be fine. Over that, you will begin to see issues.
Would like 10 km bradcast to two access points 2km and 5km
Withatleast a 50mbps connection
I started looking at carrier licenses
I then wondered where does the internet come from in the first place
Is it mainly submarine cables connecting the world?
Do we have a new acooperator here or is this any kind of his reincarnation?
I come in peace jarda, Im on a knowledge quest
The Beauty of this internet is we can communicate across the globe to learn and educate eachother in a positive manner, Excuse my lack of understanding and theories
These Airfiber ap, Suggest very long range ill put them to the test, with mikrotik routers
