Wi-Fi Tester requirements:
Shall be configurable as Access point and STA \client
Shall support Standard 802.11 a/b/g/n/ac/ax
Shall be independantly configurable to Frequency Bands either Band 2.4 GHz or 5 GHz (need to test separately with 2.4GHz mode and 5GHz mode)
Shall support up to WiFi-6 ( Please let us know if you have model supports up to WiFi7 also, what’s the cost difference )
Shall be capable to measure Test parameters : Status, RSSI in dbm, Link Speed, Throughput
Life cycle at least 10 years preferrable
Shall support Windows11
Shall have capability to control and configure through scripts for test automation.
Any AX device (except for AX Lite or L009UiGS-2HaxD-IN, they only have 2.4Ghz).
No wifi7 yet.
does hAP ax3 work for our requirement?
- Access point and STA \client -> CHECK
- 802.11 a/b/g/n/ac/ax-> Not sure about /a. 802.11 b/g/n certainly yes.
- independantly configurable to Frequency Bands either Band 2.4 GHz or 5 GHz -> CHECK
- WiFi-6 ( Please let us know if you have model supports up to WiFi7 also, what’s the cost difference ) -> CHECK (WIFI6)
- Status, RSSI in dbm, Link Speed, Throughput -> CHECK
- Life cycle at least 10 years preferrable -> depends ... but it's not unheard of for Mikrotik devices to go way over 10 years on a PER DEVICE base ...
- support Windows11 -> define "support" ? W11 clients can connect to it.
Oh and BTW this is a USER forum.
If you want official responses, you might be better off directing your request to sales or support or go via a distributor.
