Looking for a PPTP VPN Client with route adding
Hi!
I know we cannot distibute routes to VPN clients in PPTP, L2TP protocols and other, so I’m trying to find one software that allows me to set on it the routes on my internal network, because I dont wan’t my users use my central connection as gateway so I need to use routes.
On Windows I could set the DNS to the pptp connection but I cannot set any route. This should be done using the command line with route. This it’s not very easy to be done for a user so I’m looking for some application which helps my user to set these routes more easyly than a command line.
Thx for reading.
Unless I’m mistaken, pptp on Windows sends everything through the tunnel…or is my brain malfunctioning?
Yes, because by default the VPN connection has a checkmark marked called "“Use default gateway on remote network”. It’s uses the tunnel as the gateway and all the traffic goes to the tunnel.
The other day I discovered CMAK from Microsoft [2]
It seems to allow us to create an EXE with the VPN connection and routes.
I will check it and I will post here the results of my tests.
Thx for answering.
[1] http://people.chem.umass.edu/wiki/images/thumb/7/7b/Winxp_tcpip_advanced_gateway_vpn.png/400px-Winxp_tcpip_advanced_gateway_vpn.png
[2] http://technet.microsoft.com/en-us/library/cc739464(WS.10).aspx
