The subject says it all – I’ve got a nice, solid RB1100AH. It’s currently an edge router, with a 250Mb/40Mb connection to it. It serves as the edge fireall, IPv6 firewall etc. I let a PFsense box do the IPSEC and OpenVPN work because that’s easier for others to handle when compared to the Mikrotik box. It’s working fine, but it’s time to start thinking about its replacement. Thing’s I’d wish for:
Can handle a 1Gb connection – don’t have that today, but it will come
Does the usual V6, VLANs, etc – no issue so long as it runs RouterOS
USB port to support LTE modem for backup
Fanless is nice – we like not hearing the Cisco style engines…
At least five Gb ports
I don’t need wireless as Ubitiqui units are already installed, and, as mentioned, VPNs are handled by another box. I’d love to use the MT, but so far as I can tell, it still doesn’t support UDP OpenVPN etc.
BTW, all three have IPsec encryption offload. They may let you drop the additional pfSense box if you want. No reason you have to drop the pfSense box. I like pfSense.
Very nice choices – maybe the CCR9 will replace this unit and I can gift this unit to someone who’s learning about Mikrotik while coming from an old ASA. He was a bit put off by the Mikrotik CLI but, he’s learning you can get a lot of power for a fraction of the Cisco price. While I would love everything on one box, saving rack, the pfsense box is great for OpenVPN, IPSEC, etc. because anyone can set up the tunnels without my having to explain the magic of IPSEC It also means if they get the configuration wrong, it doesn’t bring the edge routers down Now if only I could get the Verizon U720L USB modem to be stable. It comes up, sometimes, and works, sometimes…
