looking for an API equivalent
Hello.
On the mikrotik CLI, i’m able to issue command like this:
/ip pool remove test_pool2
However, i’m unable to find any equivalent to that in API.
I was trying:
"/ip/pool/remove/test_pool2"
"/ip/pool/remove"
"test_pool2"
"/ip/pool/remove"
"=name=test_pool2"
Is there any way to do this w/o using .id param ?
Thank you
No, you need to get ID first.
thank you.
In menus like “/ip pool” where unique names are required, you should be able to use the name directly, but you do need to give it to “numbers”, e.g.
/ip/pool/remove
=numbers=test_pool2
And the same can actually be done from CLI too, except that giving the name “numbers” is optional, i.e.
/ip pool remove numbers=test_pool2
is another valid, but slightly more verbose way to remove test_pool2 from CLI.
