There are 3 days since I`ve opened this topic and I’ve emailed to support, but there still no reply.
If you have the solution for my problem, just let me know and I will offer you a good price for it.
Best regards,
Doru
Best regards,
Doru
Did you try the consultants page???
The best bet is to use queue tree. Then, u hv the opportunity to clearly separate the download from upload using specific chain in mangle. However, if u must use simple queue, mark upload at prerouting so that it can be penalized at Global-in and ur download can be forward and output (incase u r using proxy). Note: both upload and download must use same “parket-mark”. ROS will sort it out by itself.
I hope this helps.
Abiola
Um, this is 3 years old…
