Looking for partner to practice
Hi guys, I am looking for someone with mikrotik to try configure tunnels between them.
Just having one mikrotik it seems to be impossible :slight_smile:
Tried a MetaRouter?
Or buy a second hand device for a few bucks. You will need laboratory anyway.
Go virtual. VirtualBox or VMware Player are free, RouterOS L1 is free too and it allows you to use one tunnel of each type, which should be enough for testing. And if you throw in few other virtual routers and play a little with virtual networks, you can simulate almost anything without extra hardware. Nothing against real hardware, it does have its advantages, but virtual routers are easier, faster and cheaper to start with.
you can install one or more under VirtualBox quite easy
Thank you guys for responses, I provably should clarify my request, so here it is:
I, as non administrator, have bought mikrotik for home, looking for another non administrator beginner mikrotik user who do the same and wish to learn something new in real environment to touch it with hands and do something cool
In my opinion it is great ability to learn, test, and connect with someone.
Yet again I do not asking for mature administrators to take their time and teach me something that I can learn my self, I totally understand that your time do not worth it, just think of my request as a try to find new friends in mikrotik community thought learning and trying what it can do
Thank you again I think that post should be here for a while time so if there is someone like me we can get in touch, if it is not right place - feel free to close topic
Regards
Alexander
