Can someone point me to a place to buy/build hardware for a MT server?
I’m looking for a price point maybe under $500 for a 1U MT router with:
3 or more ethernet interfaces (at least 1 GigE ethernet adapter)
Reasonably fast Pentium Processor
Either solid state or low capacity HD (not storing anything on it like proxy)
Reasonable amount of ram (128MB or higher should be fine I guess)
I use VRRP on a pair of these for each site for redundancy so I don’t really care if it’s the best in class hardware.
I used to buy old Intel servers off of Ebay for like $250, but they didn’t have GigE adapter and the processor was only a pentium III 1GHz
While not a rackmount, the thin-routers that wisp-router sells work quite well for ethernet only applications and the price is right. You’d have to buy a dual-port gig-e card but there is room for one PCI card. Portwell.com has got some nice rackmount computers that are probably just what you need, but I’m not sure how much they are - we haven’t purchased one yet, but plan to soon.
I would think for gig-e, you’d want a Pentium based board or a healthy VIA based board. There are a lot of new VIA boards out there, but some have problems when saturating the PCI bus. We’ve never run into this with ethernet cards, but have also never tried gig-e with the thin-routers. I think there are a few members here that might have more useful info about this
I’m experimenting with the 1U 14" rack mount CSE-513L from supermicro. The motherboard faces backwards so your ethernet ports are forward. I’m pretty sure I can get a working MT prototype for under $500.
The case/ps/mobo (superserver) is like $500 from newegg, and then whatever is costs for the cpu and ram. Definately the best way to go for a router I think.
This is exactly what we do. We have bunches of these out there.
The latest ones we build use
SC512L ( the rear-facing )
P8SCI ( motherboard with dual gig ( broadcom chip ) )
snk-p0011 ( heat sink )
cse-pt66 ( air duct )
cse-rr1u-x ( riser card ) NOTE!! this motherboard is 3.3V pci only!
rb-44 ( we had it modified to 3.3V by wisp-router )
P4 2.66ghz / 512mb / 64MB DOM with lvl 5..
The 513L-160’s come with 3.5, I’d have to purchase the optional 2.5 bracket. But I’ll be using the IDE Flash from MT. Easier for field maintenance I would suspect.
You can go into the BIOS and change the fan setting from SERVER to WORKSTATION and you’ll be amazed, they quiet down to the point you can almost wisper and be heard : )
