I have 3 WAN’s into the cabinet all via ADSL2+ all from same ISP , 2 of which is business Adsl and 1 is home Adsl
I’d like to bond all 3 wan’s and have 4 Ethernet LAN to HP 1910-48 switch trunked and 1 Ethernet to guest server for hotspot control will I get CCR doing the hotspot
Is it possible ?
Currently my setup is 3 x Draytek vigor 120’s Adsl to Ethernet modems. To a Draytek vigor 3900 enterprise security firewall router
Good choice Yes, setup sounds possible.
Received it today, tried to setup with 1 wan for now while other router runs other 2 till I can migrate over.
Couldn’t get it setup to use the Adsl vigor120
Will give it another shot tomorrow afternoon
GhostWorks:
If you have a specific question, let us know.
I’ll try give it a go this afternoon.
Just wanted to get 1 wan via Adsl to Ethernet to work so I can hire a mikrotik consultant to setup the rest via the already setup wan
Tried again no luck yet , reset and going to try again , any recommendations?
Am trying to do the following setup ..
Ethernet1 > WAN1 ( Draytek Vigor120 Adsl to Ethernet PPPoE )
Ethernet2 > WAN2 ( Draytek Vigor120 Adsl to Ethernet PPPoE )
Ethernet3 > WAN3 ( Draytek Vigor120 Adsl to Ethernet PPPoE )
Ethernet4 > LAN1 ( VLAN1 with DHCP Server for 192.168.1.0/24 )
Ethernet5 > LAN2 ( VLAN2 with no DHCP Server for 192.168.2.0/24 )
I can’t even give the CCR an ip address for WEbfig access, Seems over my head
normis
May 23, 2013, 12:09pm
11
Perhaps you can upload the config as it stands using /export compact file=filename . Then grab the file from the Files tab.
