Loop-Back IP Configuration in Mikrotik
Is there a possibility to configure Loop-Back IP in Mikrotik…?
If Yes how can we do that..?
Regards
Rakesh
bridge interface is localback interface.
sorry, i mean loopback.
Can assign IP to this interface and use this for Routing protocols such as BGP ..?
Regards
Rakesh
Yes. I do this all the time.
/interface bridge add name=Loopback1
/ip address add interface=Loopback1 address=10.10.10.10/32
That gets you the loopback IP. Then, you can set the update-source property for a peer to be your 10.10.10.10 address. Of course, you can use a larger network than a /32, but in either event, make sure that the 10.10.10.10 IP is reachable by the peers.
