LOOP problem
Recently a message started to show up intermitently about loop detection.
I’ve changed the MAC Address from wlan, disabled Neighbor discovery, searched in the network for a similar MAC Address.
The system is running all interfaces on a bridge.
Any ideas?
Hi.
Show bribge & vlan info ?
I have same problem on Bridge with eth and vlan interface
I’ve nothing special. Not even using Vlans.
Here’s my config:
add fast-forward=no name=bridge
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6,7 band=\
    5ghz-a/n/ac channel-width=20/40/80mhz-eeeC disabled=no frequency=auto \
    frequency-mode=superchannel ht-basic-mcs="" ht-supported-mcs="" \
    keepalive-frames=disabled mac-address=4C:5E:0C:8E:EC:7B mode=\
    station-bridge multicast-buffering=disabled nv2-preshared-key=XXXXXXX \
    nv2-security=enabled radio-name=XXXX rx-chains=0,1 scan-list=5400 \
    ssid=XXX supported-rates-a/g=6Mbps tx-chains=0,1 vht-basic-mcs=\
    mcs0-7,mcs0-7 vht-supported-mcs=mcs0-9,mcs0-9 wireless-protocol=nv2
set [ find default-name=ether1 ] speed=100Mbps
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=\
    XXXXXXXX
add bridge=bridge interface=all
set discover-interface-list=none
add address=10.10.10.2/24 interface=ether1 network=10.10.10.0
/ip cloud
set ddns-enabled=yes
set servers=8.8.8.8
add distance=1 gateway=10.10.10.3
/system clock
set time-zone-autodetect=no time-zone-name=America/Sao_Paulo
/system routerboard settings
set silent-boot=no
/system watchdog
set watch-address=10.10.10.3
/tool graphing interface
add
/tool graphing resource
Disable RSTP on all Bridges
I am having the same issues, hundreds everyday.
Here my info, if somebody could help me… thank you
set [ find default-name=ether1 ] comment=“WAN Port FTTH” loop-protect=on name=ether1-gateway
set [ find default-name=ether2 ] comment=Homero name=ether2-master-local
set [ find default-name=ether3 ] comment=“VoIP Habitacion Morado” name=ether3-slave-local
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full comment=“Backup computer” loop-protect=on name=ether4-slave-local
set [ find default-name=ether5 ] comment=Libre name=ether5-slave-local
set [ find default-name=ether6 ] comment=“PLC / Sony Vaio” name=ether6-master-local
set [ find default-name=ether7 ] comment=Canal+ name=ether7-slave-local
set [ find default-name=ether8 ] comment=“PS3 / Homero cuando esta en hab” name=ether8-slave-local
set [ find default-name=ether9 ] comment=“Clientes Red 12. Switch” loop-protect=on name=ether9-slave-local
set [ find default-name=ether10 ] comment=“Cableado al techo” name=ether10-slave-local poe-out=off
set [ find default-name=sfp1 ] disabled=yes
set 7 default-vlan-id=100
set 8 default-vlan-id=100
set 9 default-vlan-id=100 vlan-header=add-if-missing
set 10 default-vlan-id=100
/interface vlan
add interface=ether9-slave-local name=vlan-100-eth9 use-service-tag=yes vlan-id=100
add interface=ether9-slave-local name=vlan-300-eth9 use-service-tag=yes vlan-id=300
add fast-forward=no name=bridge-airbnb
add fast-forward=no igmp-snooping=yes name=bridge-clientes priority=0x8001
add admin-mac=00:0C:42:BC:80:2B auto-mac=no fast-forward=no igmp-snooping=yes name=bridge-local
add bridge=bridge-local interface=ether6-master-local pvid=100
add bridge=bridge-local hw=no interface=sfp1 pvid=100
add bridge=bridge-airbnb interface=airbnb
add bridge=bridge-local interface=wlan1 pvid=100
add bridge=bridge-local interface=amer-sup
add bridge=bridge-local interface=ether2-master-local pvid=100
add bridge=bridge-local interface=ether3-slave-local pvid=100
add bridge=bridge-local interface=ether4-slave-local pvid=100
add bridge=bridge-local interface=ether5-slave-local pvid=100
add bridge=bridge-local interface=ether7-slave-local pvid=100
add bridge=bridge-local interface=ether8-slave-local pvid=100
add bridge=bridge-local disabled=yes interface=ether9-slave-local pvid=100
add bridge=bridge-local interface=ether10-slave-local pvid=100
add bridge=bridge-local interface=vlan-100-eth9
add bridge=bridge-clientes interface=vlan-300-eth9
/interface bridge vlan
add bridge=bridge-local untagged=bridge-local vlan-ids=100
add bridge=bridge-clientes tagged=vlan-300-eth9 untagged=bridge-clientes vlan-ids=300
add address=192.168.11.1/24 interface=bridge-airbnb network=192.168.11.0
add address=192.168.12.1/24 interface=bridge-clientes network=192.168.12.0
add address=192.168.10.1/24 interface=bridge-local network=192.168.10.0
add address=192.168.100.3/24 interface=ether1-gateway network=192.168.100.0
No, still waiting a solution… Changing something and still the problem
Maybe someone in your lan add a hub to extend ports capacity and plug it in the switch? :slight_smile:
