Looping/switching Queues automatically
I need help with looping Queues. Basically, I have a few queues and I need to do something special with that. I need to run one queue for 10seconds and after that, I need to run the second queue for 10seconds and then I need to loop it. Basically, I need to do the first queue (10s), second queue (10s), first queue (10s), second queue (10s) ane so on. Or I can do it also by switching queues on and off after some time… The first queue on/second queue off after 10s will be the first queue off/second queue on and so on.
I tried to do it but I have no idea how.
The quick and easy way is to use "comment" to find the correct Queue...
In the following exemple the comment must contain Q1="abcdef" and Q2="123456"
Warning Basic-Script so no Buiild-in error mitigation and Co.
Queue Flip-Flop Script
Define a Unique String for each Queue in the Comments
:global UIDQ1 "abcdef"
:global UIDQ2 "123456"
/queue simple
:if ([get [find comment~($UIDQ1)] disabled] != [get [find comment~($UIDQ2)] disabled]) do={
Only 1 of 2 Queues are Online
:if ([get [find comment~[$UIDQ1]] disabled]) do={
enable [find where comment~$UIDQ1]
disable [find where comment~$UIDQ2]
} else={
disable [find where comment~$UIDQ1]
enable [find where comment~$UIDQ2]
} else={
#Both Queues have the same Status
Queue Flip-Flop.txt (676 Bytes)
