I don’t get it. After a reboot, all Dude data is gone. It appears to be in the Dude folder under Program Files, and there is a current date on the dude.db file. I have also had problem when closing and then opening the program and it it has an older version of the data, perhaps a month or two. Can someone explain where the Dude stores the data and other files? I must be missing something.
If I changed user accounts, how does that effect the program and if I moved the Dude folder from one server to another? In other words, if I am having problems because the program is not running as a service and is associated with one user, how do I over come this limitation when moving from one computer to another or one user to another? Please help Mr. Wizard. I have lost a lot of work now and there does not seem to be any export/import setting so I assume they are stored in that database. Should I not be able to restore that folder from another data and it would work? - Scott
