Hi
I have a problem with my CAP AccessPoints.
If I connect tem direct to my router (RB3011) all works fine.
But now I have to deploy that wireless setup to its destination and connect the AP’s to a Switch.
As soon as I connect the APs to the switch the connection gets unstable.
The AP disappears and come back after a few seconds. This repeats in a endless loop.
The Log Tells:
19:13:09 caps,error removing stale connection [E4:8DXX:XX:XX:XX/34/3e06,Run,[E4:8DXX:XX:XX:XX]] because of ident conflict with [E4:8DXX:XX:XX:XX/34/e59a,Join,[E4:8DXX:XX:XX:XX]]
19:13:09 caps,info [E4:8DXX:XX:XX:XX/34/e59a,Join,[E4:8DXX:XX:XX:XX]] joined, provides radio(s): E4:8D:XX:XX:XX:XX
19:13:09 caps,debug [E4:8DXX:XX:XX:XX/34/e59a,Run,[E4:8DXX:XX:XX:XX]] previously tried manual upgrade to version 6.38.7, now version 6.38.7
19:13:29 caps,debug [E4:8DXX:XX:XX:XX/34/e59a,Run,[E4:8DXX:XX:XX:XX]] lost connection, keepalive timeout
19:13:41 caps,info [::ffff:192.168.1.102:37617,Join,[E4:8DXX:XX:XX:XX]] joined, provides radio(s): E4:8D:XX:XX:XX:XX
19:13:41 caps,debug [::ffff:192.168.1.102:37617,Run,[E4:8DXX:XX:XX:XX]] previously tried manual upgrade to version 6.38.7, now version 6.38.7
19:14:06 caps,debug [::ffff:192.168.1.102:37617,Run,[E4:8DXX:XX:XX:XX]] lost connection, echo timeout
19:14:43 caps,info [::ffff:192.168.1.102:42549,Join,[E4:8DXX:XX:XX:XX]] joined, provides radio(s): E4:8D:XX:XX:XX:XX
19:14:43 caps,debug [::ffff:192.168.1.102:42549,Run,[E4:8DXX:XX:XX:XX]] previously tried manual upgrade to version 6.38.7, now version 6.38.7
19:15:03 caps,debug [::ffff:192.168.1.102:42549,Run,[E4:8DXX:XX:XX:XX]] lost connection, keepalive timeout
19:15:39 caps,info [::ffff:192.168.1.102:53873,Join,[E4:8DXX:XX:XX:XX]] joined, provides radio(s): E4:8D:XX:XX:XX:XX
19:15:39 caps,debug [::ffff:192.168.1.102:53873,Run,[E4:8DXX:XX:XX:XX]] previously tried manual upgrade to version 6.38.7, now version 6.38.7
19:15:59 caps,debug [::ffff:192.168.1.102:53873,Run,[E4:8DXX:XX:XX:XX]] lost connection, keepalive timeout
19:16:26 caps,info [::ffff:192.168.1.102:49346,Join,[E4:8DXX:XX:XX:XX]] joined, provides radio(s): E4:8D:XX:XX:XX:XX
19:16:26 caps,debug [::ffff:192.168.1.102:49346,Run,[E4:8DXX:XX:XX:XX]] previously tried manual upgrade to version 6.38.7, now version 6.38.7
19:16:46 caps,debug [::ffff:192.168.1.102:49346,Run,[E4:8DXX:XX:XX:XX]] lost connection, keepalive timeout
19:16:53 caps,info [E4:8DXX:XX:XX:XX/34/3a4f,Join,[E4:8DXX:XX:XX:XX]] joined, provides radio(s): E4:8D:XX:XX:XX:XX
19:16:53 caps,debug [E4:8DXX:XX:XX:XX/34/3a4f,Run,[E4:8DXX:XX:XX:XX]] previously tried manual upgrade to version 6.38.7, now version 6.38.7
19:17:08 caps,error removing stale connection [E4:8DXX:XX:XX:XX/34/3a4f,Run,[E4:8DXX:XX:XX:XX]] because of ident conflict with [E4:8D:XX:XX:XX:XX/34/53dc,Join,[E4:8D:XX:XX:XX:XX]]
Is this a switch fault? Or a configuration fault?
I’m sure it’s related to the switch because a direct connection works fine.
Chris
