I have local wireless network connected to internet
I am using Mikrotik 2.8.26, Prism 2 card in ap-bridge mode (200mW) and Atheros 5213 card for link to the ISP
I have a problem:
during loading in local (playing games etc.) I am loosing connection to the ISP
I believe that the problem lies in Mikrotik settings
wlan1(local) ip 192.168.100.1/24
wlan2(ISP) ip 10.5.51.214/24
routing settings:
ip routes gateway 10.5.51.1
ip dns static 10.5.51.1
ip firewall source nat masquerade 198.168.100.0/24
I have adjusted hotspot,which is functioning well
I am so sorry for bothering you, but I am still a beginner in this field
Looking forward to your answer
Are you able to play games etc or download a large file from the ISP/Internet using a wired connection to the MikroTik without disconnection from the ISP?
Sorry for all these questions I’m trying to eliminate possible problems one at a time.
i am able,and the download goes fine,using wired
connection,and wireless from the ISP over Mikrotik,until I load Prism 2 card,
and then Atheros card simply loose connection (it looks like that the ISP dont
even exist!)and it look for it for a short time,then make connection for a
while,than loose again…and all that again and again during forcing in the local
i doubt that some packages are going throuhg from the local to the ISP and
roam ,or somethimg like that…
I have had exactly the same problem due to interference from an access point based on the Prism 2 chipset. I moved the access point to another location and that solved my problem. The only advice I can give you based on the information I have so far is to attach an external antenna to the Atheros based wireless card and place it as far as you can from the Prism 2 cards antenna.
