hello there,
i do since weeks some tr069 testing. - i do a custom default-configuration with netinstall - everything is fine here:
BUT
if i do a softwareupgrade the custom default configuration is not any more available.
any support for this?
thank you!
christian
Kindly explain how you did the software upgrade
Sent from my LG-H810 using Tapatalk
hi!
i did the softwareupgrade via tr069:
pushing via acs the URL:
“Username”: “casXXXXXX”,
“FailureURL”: “”,
“URL”: “http://load.xx.at/mt/upgrade-ros-6.42.2.xml”,
“TargetFileName”: “”,
“FileType”: “1 Firmware Upgrade Image”,
“FileSize”: 0,
“SuccessURL”: “”,
“DelaySeconds”: 5,
“Password”: “casXXXXXX”,
“CommandKey”: “”
Which version did you upgrade from? A few versions back there was a bug, that the Netinstall config was not becoming the default one.
steger
5
hi nomis,
i just did a upgrade vom 6.42.1 to 6.42.2
greetings
christian
hey normis,
do you know in which version this should work?
or is it a current bug?
thank you!
christian
steger
7
hi again,
any update so far when it shoud work?
thank you!
christian
