Hallo,
please, I have connected LoRa R11e-LR8 to USB with an miniPCIe adapter. I see LoRa in USB resources, but not detected in LoRa module.
Can anybody help me what to do?
Thanx a lot!
Did you install optional iot package, available in extra packages archive from Mikrotik’s download page? Make sure you download archive, suitable for your device (architecture of CRS125 is MIPSBE) and for exactly the same ROS version as your device is running.
In recent versions, lora functionality is part of iot package. Even though lora package exists, it’s not necessary to install it, it only exists for backward compatibility (upgrading from earlier ROS versions).
Thanx for answer mkx,
yes, I have upgraded packages and routerboard firmware to 7.13.2 I have installed packages iot and lora 7.13.2 I also changed USB mode to mini-PCIe I have restarted many times, disconnected and connected radio from USB, nothing happened. I see USB device, but no LoRa radio.
Is there possible any other diagnostics?
