LoRa to Home Assistant
Hi Guys
I have a LoRa Gateway connected to The Things Network.
Using TTNV3, I have the Integration passing data to Home Assistant.
Does anyone know if you can directly configure LoRa to pass directly to Home Assistant, with out using The Things Stack on an internal network?
LoRa to MQTT?
Cheers
Please excuse my ignorance as I am new to MikroTik devices. Does the LoRa device use RouterOS or would that be too verbose for it?
There is a big push for such devices here in South Wales. I currently use Home Assistant for a few tasks but mainly monitoring a ground source heat pump via MQTT. Few other MQTT feeds as the broker runs on the Linux laptop running HA.
I am looking to use MQTT to get metrics from the router and 4G (LTE) modem.
Home Assistant monitoring of modem and router…
Currently, you can only send LoRa traffic to a LoRa server directly and you can not “push” it via MQTT yet.
Any news?
I’m trying to use iot package https://help.mikrotik.com/docs/pages/viewpage.action?pageId=63045633
v.
How did you achieve that?
