I’m using an RB-493G as office wired/wireless router but I’m experienced the following problem since upgraded to ROS 6.xx.
All ethernet and WLAN interfaces are assigned as bridge ports and bridge uses 192.168.0.1/24 IP address.
0 R name="bridge-lan" mtu=1500 l2mtu=2290 arp=enabled mac-address=02:00:00:00:00:01 protocol-mode=rstp priority=0x8000
auto-mac=no admin-mac=02:00:00:00:00:01 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.0.1/24 192.168.0.0 bridge-lan
1 192.168.1.164/24 192.168.1.0 ether1-wan
2 D xxx.xxx.xxx.xxx/32 xxx.xxx.xxx.xxx pppoe-wan
Sometimes, with no obvious reason, bridge is losing its configured IP address which is then getting assigned to WLAN interface. When this happens, ether1-wan also lose its statically assigned IP.
BTW, this never happened before (with ROS 5.xx). Any idea?
