Losing flat ping packages over IPsec
Status:
Two CCR1036 RouterOS 6.15 connected over SPF+ optic connection. Over Ethernet connection is created tunnel IPsec connection
Ethernet test
flat ping on Ethernet: NO pings lost
IPsec test
flat ping test: loosing 10 packages per hour; ( no other traffic on line)
IPSEC config
/ip ipsec peer
add address=192.168.197.2/32 enc-algorithm=aes-256 local-address=\
    192.168.197.1 policy-group=default secret=test
/ip ipsec policy
add dst-address=172.16.198.0/30 sa-dst-address=192.168.197.2 sa-src-address=\
    192.168.197.1 src-address=192.168.198.0/30 tunnel=yes
Any suggestions? Is 1590 MTU2 too low?
Packets can be dropped if they arrive out of order over the ipsec tunnel.
And 10 packets per hour is nothing, you shouldn’t worry about it.
Thank you for information.
Regarding that I have direct connection how high MTU2 would you suggest?
Set it according to your needs. CCRs support MTU up to 10k, so there shouldn’t be any problems with 1590 MTU
