I have been using IP > Firewall > Mangle entries to set different IP routes. It has worked great so far.
I just upgraded to RouterOS Webfig 6.32. I noticed that I lose my mangle entries if I reboot the router.
I can re-create the mangle entries and they work. If I click on System > Reboot, the router reboots OK but all my mangle entries are gone.
This did not happen in 6.31. It only started happening 2 hours ago when I upgraded to v6.32.
I sent a supout file to support, but was wondering if anyone knows what is wrong.
Thank you.
Rizwan
marting
September 2, 2015, 8:30am
2
Can you post an example of one of the lost rules?
agrisvv
September 2, 2015, 1:40pm
3
same me on rb1100ah. upgrade to 6.32.
and now i lose mange entries, ad in WAN connection show me extensive broadcast/loop/multicast…
damit, now it think how to downgrade and restore from backup
as i can see mikrotik revoke 32 version from currient..
raxxy
September 2, 2015, 1:45pm
4
+1.
Brand new set of routers, this issue is occuring.
raxxy
September 2, 2015, 1:55pm
5
Got this issue today on some new devices.
I upgraded to 6.32 before doing anything, so initially assumed devices were faulty.
agrisvv
September 2, 2015, 2:23pm
6
if someone else read this topic for solution.
if you have last backup and not modified anything from after upgrade to 6.32, then just install 6.31 and restore from backup.
if you had modified rules then:
i had 01/03/2015 backup ( do not know witch versions of routeros 6.xx), last backup was after 6.32 upgrade
so i:
install virtual machine mirkotik x86
restore it from your last backup.
then export this filters to your production router.
worked for me.
I have confirmed that this is a problem with RouterOS 6.32.
With 6.32 I am unable to keep my mangle entries.
I downgraded to 6.31 and my mangle entries survive a reboot.
Are these upgrades tested thoroughly before public release? If not, this is really bad practice.
Rizwan
