losing packets + jumping ping =[ Help needed
Hello guys, so im using RB 411 + R52 at both sides. Linkink lan enthernet.
My friend is buying internet from same supplier and we are connected to same switch. (just i using it trough mikrotiks @ 0.5. km) I started to getting lag in games on xbox. We pinged today one server, and i have 7% packets lost + response time is jumping. While friend had 0% lost and stable response time.
So here i see that the problem is with mine mikrotiks :frowning: What can i do? Any help appreciated.
Try to provide more information for our study…
  1. How is you wireless setup?
  2. Have you try with change to other channel?
  3. what’s is you tx/rx ccq (try to get more information at station > wireless > status)?
  4. What type of the antenna are you using?
Im using:
5Ghz-turbo
Station wds and ap bridge at other side.
Im tryied to change frequencies, it seem that it helped a little, but problem still remains :frowning:
3) what's is you tx/rx ccq (try to get more information at station > wireless > status)?
This will answer later. Also one noob question:
  1. Why i cant connect to mikrotik when connected after router ?
Also today im turned off nstreame. Now ping is jumping from 36ms to ~500ms with packet loss.
:frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning:
any help ?
If you bandwidth requirement is <25Mbps (in+out)
Try not to using 5G-Turbo.
Beside this, you tx power is too high, you should reduce it and get it within -55dbm ~ -60dbm.
How to reduce tx power? Will try playing without turbo.
change wireless mode to manual tx-power and change the power to a lower number.
one noob question: why i cant connect to mikrotik when trying to connect trought router? must forward any ports or somethink?
It should be easy answer i guess. Noone?
Im connected like this: PC → Router (D-Link) → Mikrotik; And like this winbox cant find anythink.
When connecting like this: PC → Mikrotik; Then its working.
I prefer to make it working with trough router.
you are same level with the mikrotik (PC and Mikrotik connected to LAN interface), or you PC is at WAN but you Mikrotik is at LAN?
Not sure, but i think both are connected to LAN
If then, let check first…
