giganet
December 19, 2006, 5:46am
1
In trying to solve another issue I am working on in another post I have somehow managed to render the RB112 in-accessible VIA, WinBox or NeighborView.
In WinBox I have tried using both IP and MAC with no luck.
In NeighborViewer I have attempted MAC Telnet with failure.
The only way back into the router after ethernet would be a fully pinned null modem serial cable, correct?
Thanks for the help
sergejs
December 19, 2006, 7:04am
2
Yes, you have to find Null modem cable and access router via COM port to check the configuration and probably perfrom ‘system reset’.
giganet:
Thanks for the help
Hello Friend,
i think yes, only with serial DBF9-DBF9 null modem for last action by Terminal console [HyperTerminal Windows].
only that way for connect to your router.
good luck…!!!
