I had a look at the config, not sure what you are doing with zerotier, as you have a zerotier interface on the bridge and have chopped up the single vlan subnet vlan5, into several segments or instances of zerotier. Not a zerotier expert but it looks very weird to me.
Also you have many vlans identified all going trunked on th sfp plus port, but you have no dhcp server or dhcp server network or ip pool for any those vlans? So no clue what is going on there.
You have ether7 and ether8 doing something but not sure what...... other than some link with ether7 and one of the zerotier instances............ all very baffling.
You have internet detect set, which is known to cause weird problems and should all be set to NONE!!!
The bridge no longer has any need for being a member of the LIST LAN, remove it.
You have a *32 for an interface that you identify as being on the LAN, what is it????
The wireguard entries are making no sense to me. You have no wireguard to speak of, only the Proton VPN, the rest of your wireguard is BTH related. Are you stating the router added those BTH interface peer settings automatically?
Your DHCP-server network is confused.............. either you have a 192.168.1.0 network or 192.168.0.0 network, make up ones mind. Your pool for the vlan5 also doesnt match up.........
Final comment, how in the heck are you forwarding ports if you dont have a public IP on this router......
If you did have a public IP, then one would have normal wireguard running NOT BTH..........
Very confusing.
I cannot help much further as nothing is clear and have no experience with zerotier.
If you got rid of zerotier and explained what the requirements are........... I could possibly help.
I would start from a deafult config almost and then add the things you need to get the traffic your users/devices need working, and cut the extra......... for now.
