lost connection dynamic wlan and bridge
Hi.
We have large network with 100 pcs cAP and CAPsMAN.
Only 5 Ghz used.
CAPsMAN provide two SSID. And cAP have two dynamic interfaces for 5Ghz and two SSID.
All works fine. But sometime one cAP have a provlem. Users can log in and I see it on CAPsMAN. But can’t recieve IP address.
Other cAp in same time work fine. In same time on problem cAP I make ip interface with vlan - and it recived IP address.
I’m try fixed address on client - no ping.
I think lost connection between dynamic WLAN interface and target VLAN
Only enable - disable capsman on Cap or reboot can resolve this problem.
CAPs may work a month or have this problem in one day for 2-5 CAP. Usually one CAp per day ))
Can somebody help - that config post ?
Hi cadet
Can you post config export for capman and cap so we can see what you are running?
I am sure there has to be a reason the caps lose their connection also at the time the cap goes down is there anything in the capsman/cap logs
showing any strange behavior
