The connection to CPEs established
forgot to renew new interface (R52nM) in bridge (wondering how it could work before, without this change)
With default-authentication=no beacon loss happens more rare and 1x in one peace, but they are back when I rise signal strength on AP on RB433
I suppose that the worst is after me - it’s not ideal, but I’ll watch connection for stability. But I don’t know what to do except change cables when weather permits.
Could help change default-authentication on wlan1_AP?
0 R name="wlan1_AP" mtu=1500 mac-address=AP2-MAC arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name="AP2NAME" mode=ap-bridge ssid="xxx_1" area=""
frequency-mode=manual-txpower country=[COUNTRY] antenna-gain=0 frequency=2427 band=2.4ghz-b/g scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=10
tx-power-mode=all-rates-fixed noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=xxx_def disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 hw-retries=15 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=rts-cts hw-protection-threshold=256 frequency-offset=0
1 R name="wlan1_CL" mtu=1500 mac-address=CL-MAC arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="CLNAME" mode=station-wds ssid="xxx" area=""
frequency-mode=manual-txpower country=[COUNTRY] antenna-gain=0 frequency=2472 band=2ghz-onlyn scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=manual-table
periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=no default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=xxx_def disconnect-timeout=10s on-fail-retry-time=1s preamble-mode=long compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any ht-extension-channel=above-control ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 hw-retries=15 frame-lifetime=0
adaptive-noise-immunity=ap-and-client-mode hw-fragmentation-threshold=disabled hw-protection-mode=rts-cts hw-protection-threshold=256 frequency-offset=0
