Today all our customers who has puplic ip with Mikrotik device stop working. When we check for understand what happen, we see that the ethernet interfaces of these devices are not working , and some SXT reseted.
So I wonder to ask if is that related with any security vulnerabilities ?
Hi anav,
Power outages?
these devices at in different places and there were no Power outages at their place…
Didnt pay internet bills?
devices not working, ether ports not work.
What is the reason for the failures?
I dont know. thats why Im sharing this problem in here. all other cpe’s are working. but who has puplic ip it’s not work. all of them has same problem.
Two possibilities come to mind
a. ISPs changed their setup
b. routers changed their setup - DiD you implement firmware updates at the time of failures?
we are supplying to internet to these customers and we did not change any setup, we did not implement any firmware. there are more than thousand cpe. and only puplic ip assigned mikrotik’s affected.
there is no any wifi signal also, most of them LHG and all of them same problem… bios seems lost. we copy one of LHG bios and transfer it to broken one and it worked. but now the licence has problem,device worked and telling there is no licence. and another problem all mac same with copied one.
Just a thought, but perhaps one of your customers gained access and corrupted them all. If you use the same credentials on all of your customer devices, it would not be difficult for someone to do this.
we are denied access to some ports like 22,23,8291,8728,8729..
what advice can you have for like such problems? and what was wrong with these devices, how they delete their bios firmware ?
Most people that think they have a “secure” network do not. I see this all the time.
As far as the question of how did this happen, it will be easier to determine once you have done some investigation. Right now, how it happened has many answers. Do you have remote management of the devices at the customer sites? Do you use common passwords across multiple devices? Do you permit remote management from a management subnet? These are just a few questions.
Is it the firmware, or is it the router software (RouterOS) that is removed? I would not expect you to be able to recover if the firmware is missing, but I could be wrong.
I don’t know how to erase firmware, so I can’t begin to guess what happened.
Perhaps one of your management hosts is/was compromised. Another possibility would be an as-yet-undiscovered vulnerability since it only occurred on routers with public IPs. I have perhaps 100 MT routers with public IPs and haven’t seen any go offline yet.
