lost graph after reboot router board 1000
hi
when i reload my router board 1000
i lost my graphs
plz help me
Make sure you have NTP client configured on the router, which saves the clock.
did u check the box store at disk?
Hello
I’ve got the same problem, with different device (I don’t think actually the device has to do with anything). So, after restart, the graph infos are lost.
The store-on-disk is checked, and ntp client (and server) is running.
[admin@RB450G] /tool graphing> print
   store-every: 5min
  page-refresh: 300
[admin@RB450G] /tool graphing> interface print
Flags: X - disabled
 #   INTERFACE              ALLOW-ADDRESS                                            STORE-ON-DISK
 0   DIGI                   0.0.0.0/0                                                yes
[admin@RB450G] /tool graphing> resource print
Flags: X - disabled
 #   ALLOW-ADDRESS        STORE-ON-DISK
 0   0.0.0.0/0        yes
I don’t see which files should contain this information. Here are the files.
[admin@RB450G] /file> print
 # NAME                    TYPE                                          SIZE CREATION-TIME
 0 skins                   directory                                          jan/01/1970 02:01:32
 1 console-dump.txt        .txt file                                    1 083 jun/19/2011 00:22:25
 2 um-before-migration.tar .tar file                                   16 384 jan/02/1970 02:00:23
 3 PHD2-J2VM.key           .key file                                      204 jan/01/2002 03:01:29
 4 micro-sd                disk                                               jan/01/2002 03:00:03
 5 dyndns.checkip.html     .html file                                     106 jun/19/2011 00:22:25
 6 autosupout.old.rif      .rif file                                  349 414 jul/02/2011 14:04:00
 7 autosupout.rif          .rif file                                  361 064 jul/02/2011 14:13:58
 8 micro-sd/lost+found     directory                                          jan/02/1970 02:01:16
 9 micro-sd/log.1.txt      .txt file                                    9 738 jun/11/2011 23:07:11
10 micro-sd/config-2011... backup                                      32 106 jun/10/2011 23:56:38
11 micro-sd/log.0.txt      .txt file                                    9 830 jul/04/2011 19:06:08
12 micro-sd/config-2011... backup                                     127 083 jun/13/2011 18:52:48
13 micro-sd/log-fw.9.txt   .txt file                                  130 222 jun/13/2011 15:33:31
14 micro-sd/log-fw.8.txt   .txt file                                  130 766 jun/13/2011 16:10:13
15 micro-sd/log-fw.7.txt   .txt file                                  131 199 jun/13/2011 16:37:56
16 micro-sd/log-fw.6.txt   .txt file                                  131 088 jun/13/2011 17:16:15
17 micro-sd/log-fw.5.txt   .txt file                                  131 598 jun/13/2011 17:51:23
18 micro-sd/log-fw.4.txt   .txt file                                  131 426 jun/13/2011 18:27:58
19 micro-sd/log-fw.3.txt   .txt file                                  131 224 jun/13/2011 19:00:59
20 micro-sd/log-fw.2.txt   .txt file                                  131 112 jun/13/2011 19:37:44
21 micro-sd/log-fw.1.txt   .txt file                                  131 560 jun/13/2011 20:31:05
22 micro-sd/log-fw.0.txt   .txt file                                    5 990 jun/28/2011 21:26:23
23 micro-sd/dyndns.chec... .html file                                     106 jul/04/2011 19:16:01
24 micro-sd/config-2011... backup                                     120 036 jun/19/2011 00:29:01
25 micro-sd/dyndns.txt     .txt file                                       19 jul/03/2011 10:26:06
26 micro-sd/config-2011... backup                                     164 661 jun/30/2011 21:21:59
27 micro-sd/user-manager2  user-manager store                                 jan/02/1970 02:03:28
28 micro-sd/web-proxy2     web-proxy store                                    jun/12/2011 16:09:33
What is missing from my config? Or…what is mis-configured.
No idea from anyone? :confused:
mod: I’ve found a more suitable topic here.
Sadly, it’s a kind of bug, or at least unwanted feature :frowning:
DBob,
Graphs are not saved to file which is shown at /file print.
Are you able to reproduce the problem on any other router?
Not yet.
Hopefully I will get an another router at the end of this week, with ROS 5.4. I will check this, and post the result.
I think the problem is appearing only if the NTP package is installed (ref: http://forum.mikrotik.com/t/graphs-deleted-after-reboot-on-v-5-0-slow-ntp-sync/46061/1). Try to disable NTP package and let me know if it helps, please. I am going to post my solution to that other discussion thread (more common).
Deactivating NTP package did not help me.
http://forum.mikrotik.com/t/graphs-deleted-after-reboot-on-v-5-0-slow-ntp-sync/46061/41
How this problem can be solved?
same here.
I got some days that remain on the long term logs. but nothing since.
Shipped NTP enabled.
