hAP ac running 6.45.6
I did the quick check / check for updates routine which brought me up to 6.45.6.
When the router rebooted it beeped once and then once again instead of a double beep the second time. I could not get in using the router's IP address so I pulled the power cable to reset it.
After it rebooted I got in using the MAC address in winbox neighbors, IP would not connect.
When I got in I found out I had no IP from the cable modem under IP dhcp client, it was stuck in searching mode. My private IP of 192.168.100.1 was disabled. I enabled it and rebooted but had the same problem of no internet access.
I shut down the router and the cable modem, left the modem off for 5 minutes, then turned the router on after the modem indicated it was running with an IP address. I have seen it pull an IP from the router on occasion.
This time I got in using the IP address in winbox but still have no internet access. Tools / ping does ping the WAN gateway, DNS addresses and my website but I can't ping any public IPs from windows except for my WAN IP. I can't ping the WAN gateway from the PC.
I was able to update the routerboard firmware.
Tools / IP scan sees all my LAN devices, some are hard coded IPs, others get statics from the dhcp server.
I cleared the DNS cache and it started filling up immediately. I don't get IPs when I try to ping a domain name in windows but I can ping sites by name in tools / ping in the router. I changed the first DNS address and enabled the ISP's DNS too.
This doesn't make sense to me, looks to be a routing issue but I have no clue where to go next.
/ip route> pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 68.3.201.1 1
1 S 0.0.0.0/0 68.3.201.1 1
2 ADC 68.3.201.0/24 68.3.201.72 bridge 0
WAN
3 ADC 192.168.0.0/16 192.168.100.1 bridge 0
4 X S 192.168.100.11/32 172.22.22.2 1
/ip address> pr
ADDRESS NETWORK INTERFACE
0 X ;;; defconf
192.168.88.1/24 192.168.88.0 LAN 1
1 192.168.100.1/16 192.168.0.0 LAN 1
2 I 172.22.22.1/30 172.22.22.0 to IND
3 D 68.3.201.72/24 68.3.201.0 bridge
4 68.3.201.72/24 68.3.201.0 WAN
Afternoon update - I gave up waiting for help, reset to default and rebuilt it. One thing I noticed before I reset was my wifi interfaces were being managed by CAPSman even though I never did that.
