Hi Guys!
So! My configuration after upgrade:
/system resource usb print detail
0 device="1-0" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI" serial-number="rb400_usb" vendor-id="0x1d6b"
device-id="0x0002" speed="480" ports=1 usb-version=" 2.00"
1 device="1-1" vendor="HUAWEI_MOBILE" name="HUAWEI_MOBILE" vendor-id="0x12d1" device-id="0x1f01" speed="480"
usb-version=" 2.10"
/system routerboard print
routerboard: yes
model: CRS125-24G-1S-2HnD # new device
serial-number: XXXXXXXXXX
firmware-type: ar9344
factory-firmware: 3.41
current-firmware: 6.42.3 # new device with new firmware
upgrade-firmware: 6.42.3
/interface lte print
My modem (Huawei 3372 hilink) not preset in lte interfaces
But on this configuration:
1 device="1-1" vendor="HUAWEI_MOBILE" name="HUAWEI_MOBILE" vendor-id="0x12d1" device-id="0x14dc" speed="480"
usb-version=" 2.10"
modem “device-id” is different
routerboard: yes
model: 951Ui-2HnD # another device (i just try compare)
factory-firmware: 3.10
0 R name="LTE" mtu=1500 mac-address=0C:5B:8F:27:9A:64
modem (Huawei 3372 hilink) is preset in lte interfaces
https://wiki.mikrotik.com/wiki/Manual:Peripherals
Huawei E3372 v6.xx Works! LTE interface. vendor-id=“0x12d1” device-id=“0x14dc” There is different versions of this modem available, not all work under RouterOS. Only cdc_ecm and Serial modems are supported. Modem firmware upgrade may be necessary. For ppp mode send AT^SETPORT=“FF,12,1,16” data-channel=1 info-channel=0, other modes are explained in modems manual. USB Y LTE
I swear, on this device (my old device)
routerboard: yes
model: 2011UiAS-2HnD
current-firmware: 6.36 # and old firmware
upgrade-firmware: 6.36
usb-version=" 2.10"
and this usb HUAWEI Modem are worked fine, and LTE interface are preset and have worked fine!
Question!
Why on my new device model: “CRS125-24G-1S-2HnD” and new firmware “6.42.3” my modem (vendor-id=“0x12d1” device-id=“0x1f01”) can`t show and work LTE inteface?
P. S.: then i connect my modem (vendor-id=“0x12d1” device-id=“0x1f01”) to device “951Ui-2HnD” - LTE working fine!
Whats wrong with my new device “CRS125-24G-1S-2HnD” and detection usb modem?
Where are the problem?
