I have a hAP ac2 configured as a CAP.
I tried to enable VLAN-filtering, and have now lost webpage (WebFig?) access to my AP. I tried to follow the steps in https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Management_access_configuration to allow untagged (straight from my MacBook via ethernet cable) access, but that didn’t seem to work.
I have two bridges, so I feel like that is the culprit, but I am unable to access the router’s management page.
This is the last configuration, before I enabled clan-filtering on brigde=cap_bridge.
What I would appreciate help with is, given I have a MacBook, how can I regain access to my router?
I can plug into eth5 and access WAN; when I plug into ports 2,3,4, I get assigned an IP (usually 192.168.88.254) but cannot ping 192.168.88.1 or 8.8.8.8.
add admin-mac=2C:C8:1B:D1:C9:68 auto-mac=no comment=defconf name=bridge
add name=cap_bridge
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-D1C96C wireless-protocol=802.11
# channel: 5765/20-Ceee/ac(28dBm), SSID: sanctuary-5, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-D1C96D wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment="Management Access Port on eth2" interface=ether2
add bridge=bridge comment="Management Access Port on eth3" interface=ether3
add bridge=bridge comment="Port 4 on iot vlan" interface=ether4 pvid=30
add bridge=cap_bridge comment="Port 5 on private vlan" interface=ether5 pvid=10
add bridge=bridge comment=defconf interface=wlan2
add bridge=cap_bridge interface=ether1
/interface bridge vlan
add bridge=bridge comment="vlan1 access port on eth2/eth3" untagged=ether2,ether3 vlan-ids=1
/interface wireless cap
set bridge=cap_bridge discovery-interfaces=cap_bridge enabled=yes interfaces=wlan1,wlan2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add comment=defconf disabled=no interface=ether1
add disabled=no interface=cap_bridge
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system identity
set name="MikroTik hac2-2"
/tool mac-server
/tool mac-server mac-winbox
