lost password
I’ve lost my password. Is there any way to find it from a cfg file or etc on router’s HDD. I’d like to use netinstall but not sure if I lose my old configuration too.
Thanks,
Reinstall with netinstall, and yes you will loose your config.
Dear ,
If you have backup , please use this website and chose the backup and the website will show password …
http://www.mikrotikpasswordrecovery.com/default.aspx
