Lost SSID on ap-bridge: how connect to station?
I had a routerbord in ap-bridge mode connected to a station wds.
I lost configurations on ap-bridge, so I don’t know SSID on remote device.
How can I get it?
I know I can see SSID on station from ap-bridge through Snooper, but vice-versa?
thanks.
1: You need to enter the WDS station router
or
2: You need to read your documentation about the installed AP-bridge
or
3: You can restore your backup file
or
4: You can use a linux distribution like backtrack with a wireless card with the Promiscuous mode enabled and see what is looking for this station router using aircrack-ng or something like that.
AFAIK is not possible to see the SSID of a station mode ap. Next time you should mark the “ignore SSID” on the WDS tab, to avoid this ; )
If you are the owner, just login and check.
It’s that simple, but i foresee you trying to access “somebody” network and plan to disturb it.
stop it.
