lost with usermanager
when the usermanager is enabled and run , how can the user log in , i mean is it the same as hotspot ?? coz my client cant connect to my network when i enabled the user manager ever !!!
user manager is just to manage hotspot users. it is a feature to improve your hotspot management, it does not replace hotspot.
first configure hotspot and test that it runs fine. then configure user manager. then set your hotspot to use radius for user management (radius = user manager). then start adding hotspot users in the user manager.
well where can i get a download for the rb532 board this version tells me i can only install it on an i386
There is no RB500 user manager package (MIPS version), only for x86:
http://wiki.mikrotik.com/wiki/MikroTik_User_Manager
should we expect 1
it does not have enough space and does not have enough resources
i guessed as much thanks anyways. so what kinda board can i change to that would have enough resources. i want one that i can also put on a mast like the rb500
normis , thanks a lot .. now i can use user manager in the right way .
I would suggest using a PC Based MT Router on the back-end for one purpose only, USERMANAGER. If you really want, you could use the same MT for transparent proxy cacheing.
I’m not sure if it was intended, but I can see UM replacing seperate RADIUS servers for WISP’s and Hotspots. It would also be nice if you could change the dictionary files so that eg normal ISP’s could use it for xDSL authentication too.
the case is..i’ve already list the user of my network in the hotspot>user before i used UM.
  1. Now, how can i activate UM?
  2. Is it automaticaly export user list i’ve already added in the hotspot>user?
that’s for now..thanks for your attention :slight_smile:
Warm Regards,
Urang Bandung Tea
Hai, Friend
Many friends successed do remote userman as Radius Server, you can follow articles in this link.. :wink: http://forum.mikrotik.com//viewtopic.php?t=10035
good…luck..!
regards
Didiyek ma hurang gundul tea
Hasbullah.com
Hatur Nuhun mas Balimore.. :slight_smile:
hmm..i guess i had to get a license first, coz when i try, it says ‘limited session’ something like that :slight_smile: but 'neways thanks to Mr. Balimore for your attention..
well, i’m a bit confuse with point #2..where do i set the Radius client? And how? is it in winbox/console? i can’t find it there..or is it in the UM?
i will have the license ASAP, and tell you the later situation..
thank you..
Warm Regard,
Urang Bandung Nu Kasep
p.s: mas balimore tinggal di bali ya? perkenalkan..nama saya aries mas.. :slight_smile:
yes, thanks and you are welcome…
ok later..
hi all Mikrotikers..
now i got the lv6 license..
straight to the case:
  1. how to enable Radius client?
  2. i go to /radius add then which address i have to log to as a radius server? is it the RouterOS address?
  3. when i add Router in the UM with ip address=RouterOS address and the same secret key, then i try adding user with pass it show : “internal error (failed to add filter-out rule: jumps to builtin chains not allowed (6))”
that’s it for now…i need your help desperatly :frowning:
thanks before..
forget posted above.. :slight_smile:
finally i succed to communicate my hotspot with the UM..so sorry for that..
but then:
  1. I discover that in the status page.. the ip address shown is not the same with the PC’s ip address i’m using for login. And its (the ip address) keep changing everytime i login. How could this be happen? am i missing something?
  2. How to adding price per hour for every user logon in the UM?
  3. Can i printed it out i.e. every month of their uses to connect the net?
thanks..sorry for the trouble
every replies i appreciate that..
Warm Regard,
Urang Bandung Nu Hebring Tea
anyone could help me please??
now ip hotspot can’t communicate with radius server :frowning:
