Lot of IP Valid
Hello Folks,…i am using a MK about 4 mouths..
I need some informations about mikrotik:
1 - 750 GL, can i use 2 router ports ? I show what a wanna know..I want use 2 internet link.. but when i connected a mikrokit..so it show me only first port based ..a ROUTING. need I to my other box ?
2 - My first provider .give me 8 ips.. ( 6 on true).. but ..i need to use nat One.to One..or ..i dont know exactly the NAt name..but..
I wanna use a different Valid IP .. Exchange..and HTTPS.. also… FULL NAT..
How can I do it ?
Regards..for all,
about first - you can configure ports on all RouterBOARD routers as you require, initial configuration is there only to ease the installation.
about second - use 1 to 1 map or create src-nat and dst-nat rules that will NAT to and from specific address. also, make sure that when you use 2 WAN connections coming in go out through the same port (WAN)
Thank you for you support…
About ports setup to router … maybe something related to master port.. i will test again ..and told you.
About NAT, it is fine using na NETMAP, but a question:
Filter doesnt apply when you use NETMAP ?
After, i created NETMAP… the IP is right now but the Mikrotik Filter is not get
:frowning:
