Lots of dropped 10.132.88.1:67 packets from WAN port
I see a pair of these broadcast(?) packets every 25-35 seconds whenever I enable logging on this FW rule:
3    ;;; defconf: drop all from WAN
      chain=input action=drop tcp-flags="" in-interface=ether1 log=no log-prefix="WANDrop "
16:46:36 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 394
16:48:53 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 344
16:49:14 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 394
16:50:49 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 394
16:52:41 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 344
16:53:04 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 344
16:53:30 firewall,info WANDrop  input: in:ether1 out:(none), src-mac 60:73:5c:72:23:d9, proto UDP, 10.132.88.1:67->255.255.255.255:68, len 344
Is my ISP checking to see if I’m alive?
10.132.88.1 is DHCP server.
If it is not provider’s DHCP server contact provider and give him this info.
Also check if you have DHCP client run on ether1…
