Hi friends, please suggest a good low cost WIP system for our local WISP setup. I found SXT LITE 2 is good for client side. Also please suggest good antenna for WISP end. We are expecting around 20 customers at the beginning. So we need low end system for starting our business. SXT LITE 2 is good for WISP antenna ? What is the average coverage area for the antenna. Also please let me know expected coverage for the antenna.
You can use the 6dBi omni antenna which comes with the board. Or, can find third party omni antenna (TP-LINK, ALFA, Hyperlink, etc.)
It’s a WISP AP with ROS. Its price is $99.
How is the performance for Omni direction antenna come with the board ? How much users can handle Metal-2SHPn at a time. Any other low cost alternative for SXT LITE 2.
You have to answer some questions before more can be said;
What is the bandwidth available to offer to your clients?
How much, and how (all share all, or each has a portion) is the bandwidth assigned to your clients?
What are the distances from AP to clients.
In wat spread ‘seen’ from the AP are the clients? (360 degrees around > Omni antenna, otherwise sector antenna(s))
What are the prospects in growth of your network? Its a shame if you start cheap to find yourself in a situation you have to start upgrading your setup soon…
Really think about the frequency usage. If your network will be 2,4Ghz but you also place wifi routers at your clients, you are prone of destroying your own network. Better use 5Ghz for the network and 2,4Ghz for indoor private wifi.
2-5 Mbps Max. About 25 Simultaneous users
each has a portion (Authorised by PPPoE)
expected 2 KM max
As a beginner, I think Omnidirectional is good and cheap.
50-100 per annum
As you know, enabling Nstream will hide the network from normail Wi-Fi devices.
Exactly! Interference happens at the physical level of the radio waves. So no matter what protocol or modulation etc. you put on the wave, if its in the same radio band. That’s why a babyphone, microwave, or any other device working in the 2,4Ghz band can, and will, molest your radio links…
If I’d look at your future expected client base I would already start with two or tree sectors. (Or just two Omnitiks side by side, some 1,5mtrs apart and both with frequencies well spaced away from the other). This way you won’t run easily in capacity issues and by using 5Ghz you also stay much longer out any interference issues.
Also imagine this: If you install Wifi router at your clients, and they will come up with issues (they definitely do!) than you have to explain that one of the possible interfering sources at the client’s wifi is your own network! (If working in 2,4Ghz).
If your network is on 5Ghz this is not the case and actually it gives you a nice sales argument that you as professional internet supplier, are working in a different radio band than all that domestic stuff.
Everyone is saying that 2.4ghz causes interference.
If AP and CPE is set to superchannel like 2312, 2732, Does it causes interference?
5ghz devices are more expensive than 2.4ghz.
