Low disk space
I have a RB433 device, which has 64 MB of “disk” space. If I go to “Files” with Winbox, only four files are shown, their size is cca. 70kb altoghether. I have the following packages on the system:
Flags: X - disabled
 #   NAME                                   VERSION                                  SCHEDULED
 0   system                                 4.4
 1   ppp                                    4.4
 2 X ipv6                                   4.4
 3   routing                                4.4
 4   mpls                                   4.4
 5   wireless                               4.4
 6   advanced-tools                         4.4
 7   routerboard                            4.4
 8   security                               4.4
 9   dude                                   3.5
10   routeros-mipsbe                        4.4
11   dhcp                                   4.4
12   hotspot                                4.4
The question is the following: why do I have only 3928 kB of free space on my “HDD”? The resources printout:
[admin@mt-iskreni] > system resource print
                   uptime: 22h38m39s
                  version: "4.4"
              free-memory: 39024kB
             total-memory: 62432kB
                      cpu: "MIPS 24K V7.4"
                cpu-count: 1
            cpu-frequency: 300MHz
                 cpu-load: 2
           free-hdd-space: 3928kB
          total-hdd-space: 61440kB
  write-sect-since-reboot: 24180
         write-sect-total: 3540448
               bad-blocks: 0
        architecture-name: "mipsbe"
               board-name: "RB433"
Is it possible that all those packages take up almost all avaible disk space? How to verify that?
Thanks,
Nejc
I think, it’s The Dude! :slight_smile:
How about cleaning all logs (web-proxy, dude ect.)
Hey,
I am pretty new here so a hint on how to do this would be greatly appreciated.
Thanks,
Nejc
First of all, if u are new @ MT. Are You sure u need all instaled packages and Dude un RB433? U can run Dude on regulat PC without any problems. @ terminal go> file print and check stored files. About cleaning web proxy cache >IP..Web Proxy..Web Proxy Settings..Clear Cache. About dude, can’t tell u cauz i run it on regulat laptop. Sorry.
Thanks, DannyZ. I thouht I need that Dude package on RB433 to work as an agent for the Dude server. I already mentioned there are a few very small files on the storage, so that’s not the problem. I don’t use the Web Proxy so there is no cache to be cleared.
I will remove the Dude package and free up some space with that. I think it’s 10 MB or so.
Thanks,
Nejc
Dude + logs weighs lot more i think.
I have installed dude pakage on my rb 411.
How do i access it?
