I am having trouble with download speed on wireless interfaces in MikroTik Audiance (RBD25G-5HPacQD2HPnD) . I get ~15Mbps download while upload gets to around ~350Mbps. It affects both 2.4GHz and 5GHz interfaces. Things I tried so far:
- Scanned wireless channel with WiFi Scan on smartphone and MikroTik scan in Audiance and it is clear in both cases
- changed RouterOS to 6.86 and 6.94 and the problem persists (currently running ROS 7.7)
- disabled WDS mesh configuration - no effect
- did factory reset to CAPsMAN and got ~150Mbps download and ~350Mbps - download is better, however I cannot keep this config becouse it uses NAT and basicly changes Audiance into router (I need AP only in same subnet)
- checked eth1 connection speed to central switch and I get entire 1 Gbps so the problem is in Audiance
- changed hardware - I have several Audiances and every one behaves the same
I really hope you can help me, it is bizzare that I cannot watch FHD video while uploading huge files to NAS in a matter of seconds. I attach my config below:
# feb/08/2023 17:46:16 by RouterOS 7.7
# software id = 41TF-41W3
# model = RBD25G-5HPacQD2HPnD
# serial number = D5840E3ED9B0
add admin-mac=2C:C8:1B:58:FB:89 auto-mac=no name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
country=no_country_set disabled=no distance=indoors frequency=auto \
frequency-mode=manual-txpower installation=indoor mode=ap-bridge \
multicast-buffering=disabled multicast-helper=disabled ssid=LumiHOMES \
wds-default-bridge=bridge wds-mode=dynamic-mesh wireless-protocol=802.11 \
wmm-support=enabled
set [ find default-name=wlan2 ] band=5ghz-n/ac basic-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps channel-width=\
20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors \
frequency=auto frequency-mode=manual-txpower installation=indoor mode=\
ap-bridge multicast-buffering=disabled multicast-helper=disabled ssid=\
LumiHOME5S station-roaming=enabled vht-basic-mcs=mcs0-9 \
wmm-support=enabled
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256
/interface wireless
set [ find default-name=wlan3 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX \
mode=ap-bridge security-profile=*1 ssid=SYNC-58FB8C
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add comment=defconf disabled=no interface=bridge
add bridge=bridge ingress-filtering=no interface=ether2
add bridge=bridge ingress-filtering=no interface=ether1
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
/ipv6 settings
add interface=bridge list=LAN
add interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 interfaces=wlan1,wlan2
/interface wireless connect-list
add interface=wlan2 security-profile=default
add interface=wlan1 security-profile=default
/ip dhcp-client
/ip dhcp-relay
add dhcp-server=192.168.5.1 disabled=no interface=bridge local-address=\
192.168.5.6 name="DHCP Relay B"
set allow-remote-requests=yes
/ip dns static
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name="LumiHOME B (Julia)"
/tool mac-server
/tool mac-server mac-winbox
Thanks in advance !
