Hi.
Dose anybody know if Soekris 2 ports low profile lan cards http://www.soekris.com/lan16x1.htm is compatible with Mikrotik. If not is anybody aware of any other brand such cards and where i can get them?
Could you use a 90-degree riser card ?
Not really. I intend using a mini atx case for the few routers , but they wont fit a normal lan car only if the bracket but this makes the car unstable in the slot.
the National Semicondutor DP83816 ethernet controller on the
is the same how Lan-Chip of the RouterBOARD 230.
Thanks ![]()
