i think that it should i get more signal and range but i don't what's the problem,
my old system was
APP :OmniTIK 5GHz
CPE :sxt 5GHz
signal to noise more than 40 db at mode A and ccq 100%
my new system
APP : NetMetal 5 RB921UAGS-5SHPacD-NM + DualOmni 5GHz, 13dBi AirMax Dual Omni AMO-5G13
CPE: same old CPE device sxt 5GHz
signal to noise less than 25 db at mode A and ccq 75%
Note: old and new app with same configuration , same place and same position
that's my configuration :
APP:
/interface wireless
set [ find default-name=wlan1 ] default-forwarding=no disabled=no
disconnect-timeout=15s frequency=5280 hw-retries=15 mode=ap-bridge
radio-name=smartnet5g rate-set=configured rx-chains=0,1 ssid=smartnet5g
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps tx-chains=0,1
wds-default-bridge=bridge1 wds-ignore-ssid=yes wds-mode=static
wireless-protocol=nstreme
/interface wireless nstreme
set wlan1 disable-csma=yes enable-nstreme=yes framer-limit=4000 framer-policy=
best-fit
CPE :
/interface wireless
set [ find default-name=wlan1 ] disabled=no disconnect-timeout=15s frequency=
auto hw-protection-mode=rts-cts hw-retries=15 mode=station-wds
proprietary-extensions=pre-2.9.25 radio-name=hrkl rate-set=configured ssid=
smartnet5g supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps
wireless-protocol=nstreme wmm-support=enabled
set wlan1 enable-nstreme=yes
please help
