Hi there!
Hardware: 2 x Hap Ac2
I had 1 AP and it worked as standalone AP & Router, I used 20/40/80 MHz XXXX channel width in 5 Ghz band, and could download/upload with 300+ Mbit/s
After that, I’ve added 1 more else the same AP with CAPSMAN configuration on old Mikrotik.
But now, I have issue with a low speed download\upload speed through capsman (85-90 MBit/s) on the same 5 Ghz band.
Could you please lell me about my errors in configuration?
May be it’s a my fault…
I’ve attached config file of my capsman router
# oct/19/2020 11:51:28 by RouterOS 6.47.4
# software id = SW4F-3NWF
# model = RBD52G-5HacD2HnD
# serial number = D7160C2DB925
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=XX \
frequency=2462 name=channel2.4_Hall
add band=5ghz-onlyac control-channel-width=20mhz extension-channel=XXXX \
frequency=5220 name=channel5_Hall
frequency=2437 name=channel2.4_Alya
frequency=5180 name=channel5_Alya
add name=bridge1
/interface wireless
# managed by CAPsMAN
# channel: 2462/20-eC/gn(17dBm), SSID: MGTS_GPON_7D7D, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik station-roaming=enabled
# channel: 5220/20-eeCe/ac/P(17dBm), SSID: MGTS_GPON_7D7D, CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik station-roaming=enabled
/caps-man datapath
add bridge=bridge1 client-to-client-forwarding=yes name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
group-key-update=1h name=security1 passphrase=
/caps-man configuration
add channel=channel2.4_Hall country=russia datapath=datapath1 mode=ap name=\
cfg1 rx-chains=0,1,2,3 security=security1 ssid=MGTS_GPON_7D7D tx-chains=\
0,1,2,3
add channel=channel5_Hall country=russia datapath=datapath1 mode=ap name=cfg2 \
0,1,2,3
add channel=channel2.4_Alya country=russia datapath=datapath1 mode=ap name=\
cfg3 security=security1 ssid=MGTS_GPON_7D7D
add channel=channel5_Alya country=russia datapath=datapath1 mode=ap name=cfg4 \
/ip hotspot profile
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
cfg1 name-format=prefix-identity name-prefix=2.4gHz radio-mac=\
48:8F:5A:86:6E:E0
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
cfg2 name-format=prefix-identity name-prefix=5gHz radio-mac=\
48:8F:5A:86:6E:E1
cfg3 name-format=prefix-identity name-prefix=2.4gHz radio-mac=\
C4:AD:34:C0:AC:77
cfg4 name-format=prefix-identity name-prefix=5gHz radio-mac=\
C4:AD:34:C0:AC:78
add bridge=bridge1 interface=all
/interface wireless cap
set discovery-interfaces=bridge1 enabled=yes interfaces=wlan1,wlan2
/ip dhcp-client
add disabled=no interface=bridge1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=Hall
/system ntp client
set enabled=yes primary-ntp=192.36.143.130 secondary-ntp=91.209.94.10
/system routerboard settings
set auto-upgrade=yes
config.txt (3.47 KB)
