Hello im having an issue with my bonded wireless connection. I cant seem to get more than 30-50mbps through it when im bonding the connection on a single connection count.
here is the physical setup:
RB4011(E2) → AF5XHD → HEX POE(E2)
RB4011(E3)->AF5XHD-> HEX POE(E3)
I added vlans to the interfaces and bonded the vlans instead of the ethernet interfaces, mode is balance-rr on both sides
it all works as it should except the speed is terrible. If i disable either of the vlans the test will shoot up to 120mbps working just on one of the two bonded connecetions (probably limited by the cpu of the testing router)
both the rb4011 and the HEX POE has very little cpu usage.
